Home of the Spodplane
Date:  6-6-2020
Number of Hours:  2.20
Manual Reference:  21-05
Brief Description:  Strake top skin cores
Cleaned up the lines on my workbenches I used to cut the lower strake skin cores. Cut up both sides, and joined up the starboard strake top skin core from 3/8" H45, with obligitory 1" error at one point. Used the usual hinge technique with 5 min epoxy. To make the tape stick better I presanded and vacuumed the foam, it really helped.
Marking up. I only have 1.5 sheets left.
Outboard bit done, cutting the inner
Joiny, joiny. Must put that urn away...
