Home of the Spodplane
Date: 5-28-2020
Number of Hours: 1.70
Manual Reference: 21-05
Brief Description: Sight gauges
Closed up other end of sump sight gauge, clamped to a plastic container with tape to hold the end level, and into the epoxy hot box for cure.
Filled a few divots here and there.
Decided the fitting of the inlet tubes was a bit random, and devised a jig to hold them in position for cure, meaning I can fit them and one end cap in one cure cycle, saving a day. I replaced the PVC tubing jig in the starboard gauge site and marked for drilling from inside the tank. I drilled them out through both walls of the jig for a loose fit with some 3mm fibreglass rod from the bits box. I placed them back into the site, with the rods, and superglued them together from the inside. After cure I took them out, superglued the inside joint, and trial fitted after cure.
On the workbench I smeared some bondo on the jig, put cling film over it and clamped on the jig, so the bondo would locate the inlet tubes.
Popping the form off the first gauge end
Level beanie still not dissolved
Other flox plug into gauge
Copyright © 2001-2020 Matronics. All Rights Reserved. |
