Home of the Spodplane
Date:  4-14-2020
Number of Hours:  1.00
Manual Reference:  21-02/10
Brief Description:  Strake leading edge form
Have been plotting for a while now to deviate from the plans and do a version of the Featherlite pre-formed leading edge. This is what is actually depicted in the photos at the end of CH21 in the plans apparently. I have seen the Featherlite product on a couple of websites, and it is an inner skin with 3/8" foam attached, formed into the shape of the leading edge. Apparently no longer available. It looks inconveniently long, (fore and aft), and is supposed to be a bear to tape to the ribs.
To start I make a pair of cutting templates with talking numbers on them out of 3mm ply, extending aft of the 3/5.5" part intended. This is from a bit of plastic stuck onto a block of wood, which I marked with a sharpie from my laser dot projected across the ribs.
I roused out all my remaining half-way useful blocks of wing foam, mark each with the cutting template, and glue them all together with Urethane bond.
I dug out my hot wire saw, put the canard core extension back on it and restrung the wire. The leading edge is about 59" long.
Foam block glued and clamped
The Long Swift Sword of Spodman...
