Home of the Spodplane
Date:  4-9-2020
Number of Hours:  1.60
Brief Description:  Port strake assembly
Inner skin was still a bit gummy, but this meant it knife trimmed well. [Timewarp 18APR20: I have since discovered the EZpoxy knife trims much better than the MGS, even after cure. Maybe that is why I haven't had much luck with knife trimming in the past?]
Trial assemble and nothing lines up. WTF? Then notice I haven't notched the foam to make it bend, so cut the grooves with the circular saw again.
Despite being a bit gummy installed the lower skin with EZpoxy flox, then floxed on R57 & R/B33 and weighted for cure. I trial fitted all the other bulkheads first, but will install them tommorow to keep it simple.
Knife trim
Knife trim
Cutting the foam grooves so it will bend
Ribs floxed in, checking WL.17.4 marks line up.
