Trial fitted canopy hinges and I am not pleased. In the plans F-28 location the hinges are outboard of the plans canopy pads. The best location reference the pads is at about 710mm center to center. I always retreat to metric when stressed... This means the skinny long F-28 brackets hang below F-28. Grrrrrrrr. I am also aware I need to leave room for the gas struts.
Decide to make all the F-28 brackets match, and mount it where it will work, and damn the radio stack warning. I'm not goint for that many radios... More metal to achieve this is coming.
Access is awful, drilling the holes is going to be impossible, unless I can rent a rubber man.
Get very cross and decide to go back to the firewall.
Trial fitting hinges, when I thought it was going to work
