Brief Description: Cabin air vent ducting and canard fill
Removed duct part and stripped off tape. Trimmed, found good, and set up to repeat on the other side.
Not wanting to invert the plane at the moment, I made a stand to support the canard inverted, with locating pins through the upper tabs and carefully angled steel strap I hoiked just this morning from the scrap metal pile at work bolted to the lower tabs.
Hot glued some 1/16" packers to the line of the fillet/fairing and transferred to a bench.
Prep sanded for canard bottom fill. Started with long boards to identify high spots, (nothing significant), and finished with folded paper to get the low spots.
