Home of the Spodplane
Date:  5-29-2021
Number of Hours:  4.10
Manual Reference:  18-10
Brief Description:  Canopy frame internal layup
Filled the flox corner around the edge.
Applied a slurry to the mostly hard-shelled foam. (Not sure when I did this, it isn't in my rough log). 2 x BID at 45 degrees overall. Needed more bits, but the RAF BID is much nicer to work with. Used a 1" overlap. Only this BID layer overlapped the top skin, all other edge plies stopped at the edge of the flox corner. Forward, all plies are glass-to-glass with the outer skin.
As for the exterior, applied bits of 1 x CF BID on the aft frame and around the hinge points, not on the canopy flange, exceptthe last 6" or so, then 1 x CF BID overall, including the flange.
2 x UND oriented fore/aft over all. Only one was COLAN and full width, the next was RAF, with a butt joint on the centerline. Peel plied joins.
Had to clamp a taped block over the safety catch notch to get it to lay down, and again for the glass-to-glass join on the leading edge. The CF BID was very nicely behaved, not so the UND.
The first ply goes right back to the turtleback bulkhead, each subsequent is 1/2" shorter. Joins and edges peel plied. 910g resin used.
Applying slurry, somebody is trying to interest me in CFA stuff...
Wetting out CF BID
Wetting out CF BID
Is it all wet out? Buggered if I know...
