Home of the Spodplane
Date:  1-27-2020
Number of Hours:  3.50
Manual Reference:  18-08
Brief Description:  Upper engine mount reinforcement
Used new resin to place 5 x BID from upper engine mount along the outside of the turtleback/upper longeron. Wet out over peel ply and transferred, but may have been a bit much for this concept, as it was difficult to make it follow the bends.
1 x BID over foam filler in firewall.
Completed cutting off forward turtleback and started trimming. The plans have you do this after the clear forward canopy and deck is done, but I want access to the inside, and figure I can glue it on again with aligning sticks for that step.
Micro-ing the gaps
Micro-ing the gaps
Forward canopy free!
