Brief Description: Control stick/armrest/wing flow straighteners
Trimmed the left stick cover a bit more and fitted.
De-rigged the right stick and hardware, and reshaped the armrest to match the left.
Fitted a bow-tie behind the stick with urethane bond.
When vacuuming up the debris was horrified to discover a CS201 that had dropped into the armrest when I took off the stick. Probe the vacuum cleaner bag with a magnet and find 3 washers and the other CS201. Also checked they were installed on the other side. Phew!
Formed up the new cutout shape for the right armrest and, (as I'm running low on BID), 3 x UND over the result.
Whilst cleaning my sheets of glass I dropped one... Substituted some melamine coated ply. Also, we've run out of baking paper, so I used wax paper. [Timewarp: Mistake. Wax paper here is obviously not wax paper in US. Stuck to the layup like sh!t to a blanket and mostly had to be sanded off.] 3 x UND at 90 degrees, diagonally across the flow straighteners.
Final result. It might look better when painted...
