Home of the Spodplane
Date:  9-9-2021
Number of Hours:  0.90
Manual Reference:  24-08
Brief Description:  Fuselage to and canard cover/nose door fill
Relieve the interference, (again), and refit the canard. Call myself a ninnyhammer and some other choice words because I forgot to tape the surrounds. Do what I can without removing the canard.
Fit the nose door, and surround it with plastic packers secured with hot glue blocks. Hot glue some, erm, hot glue sticks to the rear screw heads so I can find and remove them later.
Prep sand, then applied a nice thick layer of fill to the aft majority of the nose door. Used my Kenwood mixer for the first time, and it does a marvellous job. I resolve to knock it down a bit afterwards to reduce air bubbles in the mix, but it does a far better job than I can by hand for such quantities.
Slather, slather
Slather, slather
Smoothy, smoothy
Smoothy, smoothy
