Home of the Spodplane
Date:  10-13-2019
Number of Hours:  0.60
Manual Reference:  24-04
Brief Description:  Sump Tank internal layup
Using AeroPoxy througout, taped the bulkheads together, 1 x BID wet out on the bench and transferred with peel ply.
Found the seat bottom I had cut out some time in the past, and applied 1 x BID on underside and peel plied.
2 x UND inline with and overlapping the bottom layups over the Sump drain and peel ply applied.
Cleaned up gear with acetone, which seems to be working fine.
Sump Tank drain
Sump Tank drain
Peel ply
Peel ply
Taping, taping
Taping, taping
