Home of the Spodplane
Date: 10-13-2019
Number of Hours: 0.60
Manual Reference: 24-04
Brief Description: Sump Tank internal layup
Using AeroPoxy througout, taped the bulkheads together, 1 x BID wet out on the bench and transferred with peel ply.
Found the seat bottom I had cut out some time in the past, and applied 1 x BID on underside and peel plied.
2 x UND inline with and overlapping the bottom layups over the Sump drain and peel ply applied.
Cleaned up gear with acetone, which seems to be working fine. [Timewarp 04sep21: I have had a series of anaphylactic reactions lately, which an allergist put down to an allergy to corn and tomato, but I have come to understand it is ACETONE! I have now gone back to cleaning everything with white vinegar, (double strength stuff Viki found), which doesn't work anywhere near as well, and will not work with the EZ-poxy. No more reactions!]
Sump Tank drain
Peel ply
Taping, taping
