Trimmed last layup, cut out access hatch to match left side, and shaped outer surface with dremel router, rounding bit in router, burr bit in die grinder and 80g.
Cut glass for outer skin.
Installed right fixed Armrests with experimental mix of urethane bond mixed with micro, (in an attempt to stop it flowing everywhere], clamped with a combination of nails, screws weights and clamps
