Home of the Spodplane
Date:  3-30-2019
Number of Hours:  0.50
Manual Reference:  20-07
Brief Description:  Rudder trial installation
Found no tool in the toolbox that adequately deals with installing the return spring onto the hook on the rudder. Bent up a bit of stiff 2.5mm wire to a pleasing shape and cut a slot in the flattened tip. Wrapped the result in bit of tape and it works well. Trial install the rudders a few times using nothing but my special tool and needle nose pliers. Takes seconds!!!
Rudders on. Rudders off. Repeat
