Layups all good, with one delam near the root needing repair. Trimmed all.
Remounted the left Rudder, and all is not level. Got confused about this, the same as I did for the Ailerons. Build up required on the Winglet pads, Root - 0.7mm Mid - 0.6mm Tip 0.5mm
