Played with CS Spar placement, Levelled the Fuselage and checked the levels. It is not quite right, and the spar is a very tight fit. Surprised me, after reading about others that had to shim the Spar up to the upper Longerons, or mount it too low, (Marc?). Hmmmmm.
After the inspection I had 30 min free so started trimming the Wing tip. I cut the top skin/spar cap/shear web with the multitool, then hogged up the foam with a hacksaw blade. Off to work!
