Home of the Spodplane
Date:  11-13-2018
Number of Hours:  1.00
Manual Reference:  20-02
Brief Description:  Winglet inner skin prep
Finished trimming lower Winglets, finding a couple of rough bits, marked for repair. Mounted on the support blocks.
Started trimming the uppers, tips are difficult, perhaps because I'm not quite doing it from the plans, more a Hoerner tip like I did like the Canard. Shaped the tip and formed a flox corner. Sanded transitions on the outer glass, then removed blobs and gluelines with the dremel router.
Cut off the fishtail, removing peel ply staples as encountered. Sanded fishtail flush with 120g block.
Scrubbed out from from the overlap and removed peel ply, in the usual small bits, with 1/4" wood chisel and needle nose pliers. Removed lumps with the chisel then prep sanded with 120g.
Prep sanded foam with 120g wrapped loosely around a bit of ply, have found this works better than glued on paper, it doesn't gouge the foam!
Transitions
Transitions
Whizzing off the fishtail
Routey, routey...
Routey, routey...
