Home of the Spodplane
Date: 8-15-2018
Number of Hours: 2.30
Manual Reference: 19-12
Brief Description: Wing attach to CS Spar
Finished off Wing attach jigs. Made one of each to the template, then made another of each to match.
Placed left Wing on jigs. Incidence is good, with 1 credit card at the BL73.25 jig making the incidence zero. Dihedral is awful, BL161.75 jig need 1.8" of packing to achieve zero dihedral at BL17. WTF? Figger I will need a new outboard jig anyway, so that each wing will fit onto one table, with room to balance the end of the CS Spar at the inboard end. Decide this will work best with a new jig at BL140.25. Screw a profile guage to a bit of masonite, and transfer profile to some glued together pallet boards. (Ran out of ply). Glued together another blank for the other wing. [Timewarp 28AUG18: To get everything to line up I need to drop the wingtip again to about 5 degrees anhedral, pretty well where the BL161.75 jig put it. Something is crook in Tallarook!][Timewarp 29/08/18: I had got it completely wrong, all above is crap, see this date for the good oil]
Trying out the Wing jigs
Wing jigged to where it should be, and making a new outboard jig
Copyright © 2001-2020 Matronics. All Rights Reserved. |
