Home of the Spodplane
Date:  8-14-2018
Number of Hours:  5.10
Manual Reference:  19-10/12
Brief Description:  Left Aileron installation. Prep for Wing attach
Reamed out left Aileron mounting points again and recessed top skin for clickbond heads with dremel router. Poor old imitation dremel is on its last legs and making a horrible bearing scream, with a pathetic runout at the end of the tool.
Greased up the hinge pins and taped up surrounds. Greased up the clickbond threads and installed with wet flox and hardware nuts, lightly torqued.
Faired heads with flox, 1 x BID overlapping 1" around heads and peel ply.
Dug out M drawings and started making the funky Wing attach jigs described therein.
Recessing skin for clickbond heads
Sandy, sandy
Sandy, sandy
1 x BID over the heads
