Home of the Spodplane
Date:  5-26-2018
Number of Hours:  2.20
Manual Reference:  19-10
Brief Description:  Right Aileron hinges
Trimmed layup. All good. Sanded leading edge BID overlap.
Tried the Aileron balance and the top is pretty near level about 8 degrees below vertical. Lovely! Had a thought, and loaded up the trailing edge with lead until the bottom surface is level, the limit for a finished Aileron. It took 0.2lb/91g to do this. There is no way I will add this much in finishing, so the Aileron is GOOD!
Cleaned remainder of glue residue from Aileron with metho.
Used Dremel router to recess top skin for clickbonds. Measure remaining material, and it is more than the plans allowance for bolts. Alles is gut! Tried out some clickbond and alignments are all off. More thought required. I don't want to enlarge the hinge holes.
Trimmy, trimmy
Trimmy, trimmy
Sanding the transition
Is balanced. Is good
