Opened up Right Wing rib penetrations for conduit and CS-151 and scooped out the clay. Had to explain to a passing wife that plasticine does not form part of the structure...
Attached IGUS EFO1-10R bearing with 2 x AN4-7 and AN960-416. Trial installed remainder of Aileron hardware to check clearance. All looks good.
Removed Aileron cove peel ply with the usual battle and contoured foam. Top worked fine with a flat wing, but the bottom was a bitch until I hot glued some timber to trap the leading edge of the wing and propped it at a sexy angle.
Rigged wing leading edge down on forward halves of Jigs #1/4
