Home of the Spodplane
Date:  4-30-2018
Number of Hours:  8.00
Manual Reference:  19-10
Brief Description:  Right Aileron
Trimmed layup, all lovely. Squared up trailing edge again and profiled.
Cut out Wing bolt access holes. Tremendous amount of resin lines the bottom, ground it out.
Marked up Aileron cuts, gritted my teeth and cut the ends on the BL, rather then 90 degrees. Despite some care the top and bottom cuts are not quite parallel, but it should be contained in the gap. Hysterical 1" error in marking the outboard bottom cut masked by cutting the accurate top one first... Used some templates with the multi tool to cut at the correct angle top and bottom along the long edge
cutting the Wing bolt access holes
Trimmy, trimmy
Trimmy, trimmy
Cutting out the Aileron
