Brief Description: Right Wing leading edge foam glitch
Ran a string line 1" aft of the leading edge on the bottom surface and confirm there is a 6mm hollow in the centre, and a straight edge along the top confirms a corresponding hump. The spars are fine, so it is just a misalignment of the leading edge foam blocks.
Removed the glue blocks from the leading edge of the jigs, propped up the tips a bit and pushed down in the middle, and could easily close the gap to 4mm. Mmmmmm. Still thinking about this. I have to fix it before fitting the top skin.
There is a thought bubble above my head filled with "????????????"
