Home of the Spodplane
Date:  2-17-2018
Number of Hours:  2.40
Manual Reference:  19-05
Brief Description:  Left Wing, lower Spar Cap prep
Made a bigger heat tent frame, old one didn't fit over the assembled wing.
Dammed forward edge of LFC-1 with taped plywood, fitted with hot glue
Taped beside spar cap and marked on it required plies. Converted the rather cryptic table for ply length so I could measure from the root for the inbound cut, and from the tip for the outboard. i.e. from the 4th ply they finish 1 26 47 65 81 and 98" from the tip.
Back filled edges of spar cap with dry micro, and filled some foam divots with excess.
Marking Spar Cap plies
Damming the edges
Damming the edges
