Home of the Spodplane
Date:  1-27-2018
Number of Hours:  0.90
Manual Reference:  19-04
Brief Description:  Left Wing hard points
Removed installation jigs and rimmed flox blobs, causing a couple of dramatic gouges in the foam.
Rounded edges of shear web with 120g sanding block, causing a couple of dramatic gouges in the foam.
Prep sanded foam with 240g sanding block, causing a couple of dramatic gouges in the foam.
Dropped a screwdriver on the tip of the shear web, causing a dramatic gouge in the foam.
Filled these and previously created dramatic gouges in foam with dry micro and used leftover micro for a bit of hardshelling.
Commisioned a second squeezy bottle of resin, and decanted the last of the current batch of resin into it. I can now do a big layup without refilling.
Could have progressed to the Shear Web, but I am knackered and it is 39C in the shed. Beer O'clock!!!
Trimmy, trimmy
Trimmy, trimmy
Rounding the edge of the Shear Web
Filling dramatic gouges
