Home of the Spodplane
Date:  1-19-2018
Number of Hours:  3.80
Manual Reference:  19-04
Brief Description:  Left Wing Cores
After some adjustment of the edges glued up LFC 1/2/3. Learnt the lessons of last time and did not proceed until each time all three blocks were set up, square, straight and aligned.
Rather than splodges of 5 min epoxy, fixed the top side of the foam to the jigs using hot glue and square glue blocks. I will admit I stuck a few on the lower surface by mistake, because that is the side they were on last time. (F*&k!!!)
Missing some pictures because the camera was in the wrong mode, and I didn't investigate why it was beeping unusually.
Last glue joint
Last glue joint
Fixing upper surface of wing to jig using glue blocks
