Home of the Spodplane
Date:  11-28-2017
Number of Hours:  2.30
Manual Reference:  19-03
Brief Description:  Right Wing Cores
Checked the jig templates against the rib templates and there are discrepancies, but what they are is difficult to determine, because they are all at different B.L. Hmmmmm.
Also a bit mystified as the cores seem accurate to the ribs, but don't slide into the jigs. It doesn't actually say they should anywhere, but it is implied. Are the cores wrong or are the jigs wrong? Hmmmmm. Removed all the jig tops and RFC 2 slides in nicely.
Replaced all the remaining dud 10mm bolts with 1/4" ones.
Tested the variac and could not get amps out of it. Discovered one output terminal had fallen apart and a good connection could not be made. Pulled it appart, bodged it up, works!
Viki arrived home then, so we cut the ends of RFC1 and the upper spar trough RFC2, which I forgot to photograph. [Timewarp 13JAN18: Don't do it this way.]
