Home of the Spodplane
Date:  9-25-2017
Brief Description:  Storage of completed bits
Little jobs covering the period 25SEP to 01OCT in amongst some other higher priorities.
As suggested by TC Len, obtained some old curtains and a doona cover from the Salvo's shop for a reasonable sum, (including the Iron Man Onesie I am wearing whilst typing this). These will routinely cover the SpodPlane and it's Canard from now on.
Used my faint memory of the wing stands required for a later chapter and made 4 mini canard stands from ply cut to the pattern of the Canard profile templates with a timber bottom bit, all padded with 3mm rubber sheet I had lying around. Extended 'noses' prevent it from falling down the back of my shelves. Chucked the Canard, (with Elevators fitted), up on the top shelf and covered it. Will probably be room on that shelf for the wings when I make 'em, if somebody takes my old smegging jigs.
On the stands
On the stands
Tastefully covered Canard
Under the Golden Curtains. This is not a euphemism. Sorry, couldn't be bothered rotating image...
