Hung ballast weights off cable tied bits of fg tube. Clips support either my 4.4 or 5kg ballast weights fixed with flox or urethane glue. Put them together and then swung them around a bit to generate a failure. Skinny cable ties fail before the clips, wide cable ties tear the BID without detaching the clip. Win.
