Home of the Spodplane
Date:  7-9-2018
Number of Hours:  0.30
Manual Reference:  16-04
Brief Description:  CS109/118 bulkhead install
Built up the urethane fillet with flox.
2 x BID over both bulkheads. Discovered I had cut half the glass I needed so hacked up some scraps. Only realise after I had started than I couldn't see the forward side of CS118, use a mirror on a stick to check progress
Glassing the control bulkheads
