Home of the Spodplane
Date:  9-1-2014
Number of Hours:  2.50
Brief Description:  Outer seat belt mounts / Rear heat duct
Finished seat belt holes.
Cut out cloth for inner surface rear heat duct. Plans say use BID. Or UNI. How to DECIDE????? I used UNI, same as the front.
Cut out foam for transition piece from the dreaded urethane, joined with 2 part foam. I only used a scrape, but it was too much. I had the part in a vise for cure so shape not affected.
Finishing holes
Finishing holes
Cutting heat duct cloth
Cutting transition piece
