Spent some time figuring out what the ply reinforcements should look like. Profile gauge was too long, so just brutalised a bit of foam to get an idea. Reproduced in 1/4" hoop pine ply using electric coping saw and 2" drum sander mounted in the drill press.
Floxed in position, then 7 x BID over the top, laid up on the bench on peel ply, cut with pizza cutter and pressed over the ply.
****F*&^UP WARNING: Read tomorrow's entry before imititating today's efforts...****
