Home of the Spodplane
Date:  8-15-2015
Number of Hours:  2.60
Manual Reference:  Step 5
Brief Description:  Canard tips
Inverted Canard and trimmed top layup.
Finished bottom profiles and cross-checked.
Plans have overlap at the LE, so will I. Plans have a glass/glass overlap elsewhere, I will use a flox corner. I think I made it a bit big, about 1/2", with a bit hollowed out under the intended overlap.
Micro'd the Kilometricos in place, can't see why it would be better to do it later. Worst that can happen is I drill 'em out again.
Filled some foam gouges and dings.
Checking hinge pin position, foam and glass profiled
Ready for glass, but not today.
