Final installed and torque checked all the rudder pedal hardware, (except 1 bolt I don't have). Had a bugger of a time with washers, so invented a pair of washer forceps from an old pair of dodgy vice grip pliers.
Spent some time on nosegear part inventory, and have not got it figgered out yet. Reckon I need a plug for P2 to go into and a bunch of pins. Time to talk to the man I got it off to see if there are spare bits there.
Removed nose gear strut, and replaced dodgy taping at forward end of gear opening, It was noted as dodgy at the time. Note while trial fitting that it is not practical to refit the nose strut without assistance.
Note that nose tyre is flat, so pump up to 40psi as a test.
