Home of the Spodplane
Date: 1-21-2016
Number of Hours: 1.30
Manual Reference: 13-9/10
Brief Description: Nose Top foam
Came back and decided it looked good.
Did a bit more sanding with 80G to smooth, then sanded the taping depressions.
[Timewarp: Should have read the plans more carefully, the depression at the rear of the nose is not just for taping, it should be 0.2" deep to clear the Canard cover, mine is half that. Didn't discover until after I'd made the door]
Marked out the run of the pitot line. Had envisioned hacking out the foam and putting it under the surface, but most of it lies under the bottom foam, should have done it before skinning the bottom. Decide to leave it until after the top is skinned and removed, deciding then to put it under the inner skin, tape it over the top of the inner skin, or somehow bunge it through the foam, like the high-performance Rudder plans suggest to do with the wings.
Marked out nose door and taped nose with box tape.
Cut PP and glass
Sanding taping depressions
Nose taped for nose door
