Home of the Spodplane
Date:  11-30-2022
Number of Hours:  1.60
Manual Reference:  23-07
Brief Description:  Cooling plenums
Quick trip to Queensland, most enjoyable.
Broke plenum off cowl and trimmed all. Looks good, but it is now shiny on the outside on the patched bit. :(
Prep sanded and taped the remaining joins on both plenums, (including the patch), 2 x UND 90/45 and peel plied.
Used leftover resin to layup a square of 2 x UND @ 90 degrees between baking paper and ply and weighted for a flat cure. Intend to use them for pushrod sealing snapperdoodles. Should have peel plied at least one side.
Last day of autumn, and I still need to heat for a cure...
Tapey, tapey
Tapey, tapey
Tapey, tapey
Tapey, tapey
Making a flat thing
Making a flat thing
