My engine mounts are here! After two years of no progress I have actual mounts, (one is for another builder).
Trial fitted both on engine, and offered up to the firewall. Bottom right mount may need a washer, and the top mounts are not flat enough. Mark up some levelling pads.
The mounts were grit-blasted this morning, so I just prep-sanded some rough bits, clean and degrease and put on 3 coats of rattle-can acrylic primer.
