Home of the Spodplane
Date:  9-7-2022
Manual Reference:  24-02
Brief Description:  Control stick cover/wing flow straighteners
Trimmy, trimmy, all OK.
Play with vortilons for a while getting my head around them, then put them away for later.
Progressively trim the stick cover until I get full travel. Happy with the result.
Klaus Zavier spoke about the wing flow straighteners on his Longez, which I note has ailerons with the edges along the airflow like mine, rather than 90 degrees to the trailing edge like the plans. His tolerances are much tighter than mine, and I got a good laugh from him and everybody when I pointed it out. They don't bind, so he is happy! Found a pattern online from a Varieze newsletter enshrined in a UK CAA document and printed them out to have a bash.
The largest of the templates was a good fit inboard of the aileron, and reasonably resembled Klaus's. I enlarged the smallest x 1.1, and with them placed 1" either side of the aileron like the newsletter suggested. (Klaus's are right at the edge of the aileron. Mmmmmmm. Mine look lovely.
Peeling off the cured result
Initial trimmy
Initial trimmy
Contemplating flow straighteners
