Mount the canard and elevators to fine tune the planning for resolving the stick interfering with the armrest, which means the stick will be hooked up to all it's controls! A little bit of hangar flying ensued.
Trimmed the left stick cover until aileron travel is right. Do not like being able to see into the stick pivot innards. Have a look at some websites and see it is a common result.
Got the canard on, and the elevators fitted, but not hooked up. Discover along the way I had forgotten to remove some of the packing protecting the hinge points. Discovered also that it is much easier to push the pins throught the rivet holes in the hinge pieces than throught the correct hole. Get there eventually.
Step back and look at the fully assembed airframe, and it looks brilliant!
Trimmy, trimmy. Result ugly.
Brrrrrrrmmmmmmm!
Canard on, and checking for travel after finishing
