I had such a bad time with the CS151 I approach this job with mild terror. I mounted the wings a while ago to get them out of the road for the engine mount jig construction. I have also downsized the workshop a bit. I no longer need BOTH workbenches, so I donated one to the local CFA for their workshop, cleaned up the remaining one and put casters underneath it to match my fixed workshop bench. I immediately notice I have to work cleaner, put stuff away instead of move it around. Not a bad thing. You can store a lot of crap on a wing too...
Make some jigs to show 20 degrees up aileron and fix to wing with hot glue blocks. Adjust CS129 length until CS128 hits the bolt at 20 degrees.
Make another jig to measure 20 degree movement of the stick and try to visualise the result.
