Home of the Spodplane
Date: 2-28-2022
Number of Hours: 3.50
Manual Reference: 23-01
Brief Description: Engine mount
Over the last week or so continue efforts to achieve the ube notching for the engine mount with mild steel tubing.
https://metalgeek.com/static/cope.pcgi
Watched a couple of videos on how to go about it, and find references to coping calculators. I find one at the link above. You input the sizes of the tubing, the angle and any offset, (which I understand is applicable to the tube that goes on the bottom of the lower cup). I found the easiest way to measure the angle was to fold a bit of paper to match the required angle, then measure with a protractor.
This generates a pdf which I printed, then wrapped each around a bit of tubing, I then pull this off and telescope it and rotate the two pieces until the paper template fits in the desire location, making adjustments with small pointy scissors. I then tape the two bits together, replace it on a tube, mark the cut, then cut with a thin wheel and trim with a flappy disc on two grinders. With a lot of false starts and practice I can reliably generate the right tube for each job.
The hardest is the bottom cross tube with the bend in it. I made a form to bend the tube over, and can generate a usable tube after 1/2 a dozen fails. All recyclable.
I attached each tube to the form with hot glue to accurately cut the next, and spend some time thinking about which order to make and weld the tubes.
Well that fits!
This one doesn't but I'm learning
