Over the last few day, taped elevator tops, inserted a packing piece of ip foam into the hinge points, then hot glue elevators to bench inverted. [Timewarp: This was a mistake, epoxy runs glued them to table rather intensely, and some damage was sustained removing them, necessitating skin repairs. Should have inserted some glue blocks between the elevators and the bench]
