Trimmed the edges to about 1/8" too high, still a bit gummy.
Drilled out the locating pin holes, taped the canopy surrounds and fitted the canopy frame with hot glue blocks. Hot glued some plastic packers along the leading edge of the frame and slathered on the dry fill from the canopy flange to the leading edge.
Cleaned up the gear with white vinegar for the first time in a couple of years. I've been having some anaphylitic reactions, and worried I was becoming sensitive to the epoxy, but now believe it is the ACETONE. I had to switch to acetone to clean up EzPoxy, but never went back to vinegar. Am using some super strong 8% vinegar Vike found for me. [Timewarp 28dec21: No further episodes].
