Home of the Spodplane
Date:  8-8-2021
Number of Hours:  3.10
Manual Reference:  18-13CC
Brief Description:  Canopy frame opening cut layups
Separate fixed and opening parts of canopy frame, and view the horribly haggled exposed foam. Hmmmmm. Decide to prep foam with wet flox to fill dings, in combination with plans flox corners.
Cut flox corners with dremel with diamond grinding bit.
Make a dam for the haggled bit of inside skin from taped aluminium flashing and hot glue in place.
Fill flox corners and prep dinged foam with wet flox, and 2 x BID over the faces. extending over the drip rail on the forward part.
Cutting flox corners, with horrible dings and damaged inner skin visible
Laying up. This is the fixed forward part, propped up against the other
The ACTUAL aft part, with aluminium patch form visible
