Brief Description: Main gear fairings and heatshield
Trimmy, trimmy, all OK. Used a paper template to match the profiles.
Installed starboard cover with cleco and pondered result.
Removed caliper mounting plate and made some paper templates for the next bit. Then refitted the caliper mounting plate, because I still need it to check the first layer of the heatshield. Hmmmmm.
