Brief Description: Canopy frame internal shaping and hard points
Marked up hinge pad locations.
Marked up 1.6" from outside of longeron and started shaping foam inside this, using surfoam plane and file, the odd bit of 40g sandpaper and the dremel sanding drum for the hard bits.
