Brief Description: Finishing 101 - ailerons and windows
Did a trial taping of the port fuselage window, as per the Glastar instructions. Seemed to work fine, though the fill is a little soft. Cory Birding and paint should fix that.
Sanded starboard fuselage window fill flat, re marked and cut the edge, and cut the flange to match. Had the startling insight that the window frame just has to be flat enough that the acrylic can follow it. Easy-peasy. If the window bottoms out in the frame I just move the edge in a bit until it doesn't.
Spend some time documented how I have done the windows so far, incorporating remedying all the boobs I've created on the way, and the Glastar instructions, gleaned from two faintly contradictory sources.
