Home of the Spodplane
Date:  2-14-2021
Number of Hours:  4.00
Manual Reference:  25-01
Brief Description:  Finishing 101 - ailerons
40g block sanded starboard aileron top and port bottom. Marked a couple of low spots.
40g block sanded nose fill and marked some low spots.
Filled some more aileron, I've lost track of which bits. I think I have had my port and starboard and top and bottom confused in some earlier entries.
Remarked fuselage window frame, and sanded to profile with 1/2" dremel drum sander. Was suprised to find this was the best and most accurate tool, and the least likely to destroy the underlying plies. Did the same for the ballast compartment window frame.
Back filled identified low spots.
Wrapped nose door in plastic wrap, then filled front part of door and surrounding nose.
Painty, painty
Painty, painty
Smeary, smeary
Smeary, smeary
Trimmy, trimmy
Trimmy, trimmy
