Hollowed out foam under open area of fixed canard, about 3" forward and outboard to the inboard edge of the rear canard tabs. Removed hot glue blobs and profiled the foam. Cut some flox corners.
Stuck some slivers of foam into gaps, mainly in the leading edge.
