Home of the Spodplane
Date:  9-13-2020
Number of Hours:  2.50
Manual Reference:  21-10
Brief Description:  Landing light mounting bracket
Trimmy, trimmy, all OK.
Drilled light baseplate and located to flange with cleco. Drilled inbound side and hot glued on a nylon tap washer, with the post located in a hole in the inbound wall. Juggled the light until I was happy with the position, and hot glued a block of 1" H45 to form the bracket.
Pulled it out and shaped the H45 until the shape pleased me, applied a flox fillet to the base and around the tap washer, then 4 x BID between the base and the H45, 3 x BID over the tap washer.
I x BID over the outer surface of the door.
Bulkhead form
Bulkhead form
In place
In place
